Results 1 to 10 of 19
04-11-2010, 01:58 PM #1
Help needed--on water and engine is not turning over
Hey guys,
Posting from my BB again. We are currently stuck on the water bc my engine won't turn over! Went out all day yesterday with no problems, and most of the day today. Its almost like its a battery problem as the engine sluggishly turned after sitting for about 30 minutes listening to the radio, but the batteries are both new. Plus I had just cranked it and moved it to keep from getting hit by these sailboats.
Now when I turn the ignition, I hear the normal beeping, and 1 click from the engine but nothing. It won't turn.
Any ideas on some things I can look for before calling for a tow?
04-11-2010, 02:38 PM #2
Have you checked all the fuses under the dash? Remove and re-seat them.
We thought we were doomed about a month ago with the boat not turning over then went through the fuses 1 by 1 and the boat turned over fine after that.2009 Outback V
04-11-2010, 02:39 PM #3Senior Member
- Nov 2009
- Murfreesboro, Tennessee
- 206
Mine did the same thing the other day and it was a ground wire loose on the block.
04-11-2010, 02:45 PM #4
04-11-2010, 02:51 PM #5
04-11-2010, 02:57 PM #6
Maybe you've checked and double checked but make sure it's in neutral!
Mine did the same thing and after bout 1/2 hour realized one of my kids pushed the throttle arm forward just enough that it wasn't reading the neutral position. Wiggled it and sure enough it started right up.
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
04-11-2010, 03:02 PM #7
04-11-2010, 03:29 PM #8
What do you think it means that the engine is not turning over? I just get that one click.
The battery connections look good.
Checked the ecu plugs. (Unplugged and plugged back in)
Did some wiggling on the harness and still does the same.
Shifted the throttle a bit..same.
Also, where is the starter? Still trying to learn where everything is in my first full summer as a boat owner.
Thanks to all of you for the help!
04-11-2010, 03:40 PM #9
04-11-2010, 03:48 PM #10
Yeah, I had read through the vapor lock, but it won't turn over so I didn't think it was that. Plus, its only 72, I poured some cold lake water on the fuel filter and plus I have been sitting here for about 2 hours. . As a matter of fact I just cracked an Amstel Light.
I am going to mess with the connections right now. They look like they could be tighter for sure.
Stand by for update......Last edited by WaterBullDawg1980; 04-11-2010 at 03:56 PM.
