Results 1 to 3 of 3
Thread: bad gas
    Aug 2005
    Default bad gas
    I am writing to see if anyone here knows the key to remove a gas tank from an 01 moomba outback. I have gotten a hold of some bad gas & it has led me to replacing a h2o separator twice, rebuilding a carb. & with no luck there, my only hope is to remove gas tank & clean it. Any suggestions on removal & cleaning? Please help! moombadog-
    Aug 2005
    Default Replying to Topic 'bad gas'
    Jeff,
    Thanks for the reply. I have tried running the boat in the driveway w/ small amt of gas w/ additive. When I do a gas sample by dumping the h2o separtor I still have residue in the gas. This is why I need to remove tank. Thanks for the suggestion. Please let me know if you have any info on removing the gas tank. Thanks Michael
    Mar 2003
    Springfield Missouri
    Run the gas out using the fuel pump and disconnect the line after the pump and run it into gas cans. Run a power source to the connections on the pump and then power the pump so not to have a spark.
    SOLD
