Results 1 to 10 of 17
    Sugar Land, TX
    Default Sumo sacks in 2010 LSV
    Has anyone swapped out the stock locker bags for the 800lb Sumo sacks? I have these already that we used in our old boat. They are 24x24x50, whereas the Fly Highs are 20x20x50. Don't mind getting the Fly Highs if I need to, but it all adds up quickly! I think these will fit, but since they have the "waterbed" type fittings, how much modification will it require? My gut tells me to spend the $$ and go with the Fly High Pro X so it's a 5 minute swap, but wanted to get input from the experts.
    Des Moines, IA
    The sumo sacks will fit but be nice and tight. You'll need to spend a few bucks to get the fittings to hook up, but it's doable. The Fly High sacs are definitely better though - better material and better fittings.
    Jul 2002
    London Ontario Canada
    there is a fly high 24x24x50 jumbo sac, i just got one
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Sugar Land, TX
    Just saw those. So at 1100lbs each, that's over 2k in the back. What do you do for the front? I doubt the 400 in the locker is enough to even it out. What is the largest sack that fits in the ski locker?
    Jul 2002
    do you have the play pen or walk thru
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Sugar Land, TX
    Walk through - 2010 LSV.
    Sep 2009
    Copperas Cove, TX
    Probably could use 200-300lbs of Pop bags plus a ballast sac(s) under the bow seats
    Apr 2008
    California
    Quote Originally Posted by you da man View Post
    You do that and i have one thing to say, be very carefull! The LSV sits a lower in the nose than the XLV and with a bow sac and extra weight of pop bags if a large roller set catches you unaware your taking serious water over the bow. I know. it's happened to me twice and both times i had a couple of inches of water across the entire floor! At least with a bag only up front you can empty out when not needed.
    Sep 2009
    Copperas Cove, TX
    I ordered 485lbs of steel shot in Pop bags. No way I intend to use it all in the bow but just all over the boat as needed. I haven't taken more than 6 in the boat and don't see more than 8 so I'd like the have the weight easier to move than ballast sacs for fine tuning. Plus the Pop bags are much smaller. I hear you on taking rollers over the bow when ballast down.
    Des Moines, IA
    A 60% / 40% split is a good rule of thumb for weighting the LSV. So if you wanted to fill your sumo sacks all the way you'd need about 1000 lbs up front which would be 600 lbs in addition to the ski locker ballast. Your boat would be slammed! With 1100s in the back you'd be up to the rubrail before you got enough weight up front. If you run over capacity consistantly make sure you've got the right prop.
