Results 1 to 10 of 13
Thread: boat choices please help
03-29-2010, 06:12 PM #1Junior Member
- Mar 2010
- 3
hey,
hows it going guys Iam looking at getting a new but used boat for my self and really could use your help. Ive been lookiing at onlyinboards.com and have found a few on there in my price range. 25-30k. iam really looking to spend less than 30k but maybe ill throw an offers at the ones listed at 30.
My first question is is the outback lsv the same hull as the mobius lsv. ans is the older mobius V the new LSV. also about engine hrs would 300hrs be alot on these motors .these are the boats i have been lokking at.if you could give be your thought that would be great. is the 03-06 lsv a different hull
2003 Moomba Mobius LSV Gravity Games 24000 330hrs 315hp
2006 Moomba Mobius LSV 28000 160hrs 325hp
2008 Moomba Mobius XLV 29000 375hrs
2007 2007 MOOMBA OUTBACK V 29000 325hrs
thanks alot guys
03-29-2010, 06:38 PM #2
First off 300 hours is nothing, i sold my last boat at 900 and it was purring like a kitten, still going strong at 1200.
The Outback LSV is the same as the Mobius LSV without a tower and ballast and a very other subtle things as i understand it per the year in question. Last year was '07 for the Outbacl LSV.
The older Mobius V is not the same as the Mobius LSV. The best hull and last change for the LSV is 2006 and up. So the '03-'05 are the same.2007 Mobius LSV
03-29-2010, 06:54 PM #3
what motor does the 08 have?
09 21v LAUNCH
99 Outback LS. Sold
Doug
03-29-2010, 07:03 PM #4
I would go with the 2008 Moomba Mobius XLV 29000 375hrs
2023 Moomba Mojo
2013 Malibu VLX 21 - SOLD
2005 Moomba XLV - SOLD
2001 Supra - SOLD
1998 Master Craft - SOLD
03-29-2010, 07:59 PM #5Junior Member
- Mar 2010
- 3
not to sure about the 08 xlv motor but all email them.
would you guys say that the XLV will be alot slower cause the it will weight alot more and prob use more gas. also Iam guessing the the VLX will throw a bigger wake thd the LSV. how would you guys rate the wake for the boats I listed.
03-29-2010, 08:03 PM #6Senior Member
- Feb 2005
- Ottawa, Ontario, Canada
- 718
Any used purchase should have a pre-purchase inspection by a marine mechanic. Make sure that it's someone who knows Indmar drives.
If the XLV is mechanically sound and you really can accommodate it (tow vehicle, storage space), it's the one that will give you "doubt removal" about having bought enough boat.
03-29-2010, 08:08 PM #7
You can look up specs and other info using the "Archive" link at the top of this page under "About Moomba". The pre 2006 lsv hull is the same as the Outback V in 06-08. Either of the 06 LSV or the XLV are fantastic boats. Check to see if it will fit in the garage though. I sold my 2000 Outback LS with 490 hrs. on it. It was still like new under the clam. Best of luck to you.
03-29-2010, 08:34 PM #8Reese350 Guest
Did you see "Emmas Moomba" in the Classifieds? If I remember correctly, it was a loaded 2008 LSV with 30 hours on it. He sounded pretty flexible on the price. Seemed like a deal to me.
03-29-2010, 09:20 PM #9
There's a reason the LSV is the best selling boat in Moomba's line-up, just the right size and does it all very well. If you're not taking 9-10 peeps out with you everywhere you go then i'd seriously consider the LSV, it's lighter and will fit in a garage (maybe). If you have everyone and your neighbor wanting to go out and your vehicle can handle the weight then look at the XLV.
03-29-2010, 09:59 PM #10Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
