Results 1 to 10 of 16
03-18-2010, 04:23 PM #1Senior Member
- Jan 2010
- Milwaukee, Wi
- 263
New Engine Break-in, but Moomba test drive?
According to Moombas website "Each boat is put through a rigorous
set of lake tests prior to being shipped." Considering Indmars engine break-in procedure how can this be possible? Furthermore, I read a post here where someone was following their boat being built and they showed someone from Skiers Choice test driving the boat before delivery and certainly they were not following Indmars break-in procedure.
Just another thing I was curious about...08 Outback
82 American Skier
03-18-2010, 04:37 PM #2
They do what they do, then the dealer does what the dealer does, then you still have to break it in.
03-18-2010, 04:44 PM #3Senior Member
- Jan 2010
- Milwaukee, Wi
- 263
Right, that much I realize. You see the conflict though...
08 Outback
82 American Skier
03-18-2010, 04:45 PM #4
lots of mis-information to this topic...
on a side note, my '08 kawasaki zx-6r has a break-in period listed in the manual telling you not to rev past a certain point for so many miles, don't remember specifics. I caught a show on the HD Channel on cable a while ago that did a tour of the kawi plant in japan. the final assembly step has a technician pulling the bike onto a dyno, hooking up some diagnostic equipment and running the thing up the rpm band. redline is 16,400rpms, and he had to be up above 14k. they did this with every bike assembled. so much for a break-in period listed in the manual with rpm limits...
had an 98 mitsu eclipse gst, an '03 mitsu evo8 and an '06 mitsu evo9. all three cars had the same 4g63 engine built in the same plant. the eclipse had conventional oil and no break-in period. the evo's had synthetic factory fill and a 1000mile break in. go figure..
seems to be 2 schools on this topic...
-follow a strict rpm limit based on hours/time and change the oil at intervals sooner than the final recommendation.
-run it hard, land the rings hard since that's what it'll be doing, change the oil 2x within the first 200 miles or couple hours to clean up metal and then go.'06 Supra Launch 20SSV-gone but never forgotten
03-18-2010, 05:13 PM #5
They're all done that way regardless or who makes it or what it is so don't worry about it. I remember my test drive, salesman drove it like a banshee and said don't worry about it, never had an issue since but i followed the rules anyway. Besides i hate to tell ya'll this but few if any will have their boats long enough to put enough hours on them to have an issue even come up. Seriously it's just the stats, most owners will sell them for a new one before that happens.
03-18-2010, 05:34 PM #6
followed the break in procedure myself, but allways wondered about that test drive before buying.
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
03-18-2010, 05:50 PM #7
I would think that factory dyno tests have to push the engine to its limits. I personally would not want it any other way.
2007 LSV - All red
Wetsounds PRO 80's WS420 Eq
Acme 1433
03-18-2010, 07:07 PM #8Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
Yes, there is a conflict. However, the manufacturer must ensure that your boat will perform like it should. They have little to no choice in putting the boat through it's paces. It would be a great dis-service to you and your dealer. It would be better to attack problems at the assembly plant than at your dealer and the consumer won't have to experience much delay when buying a new boat.
I would recommend (and do follow) the break-in guidelines as they last for 10 hours. The dealer is running the boat for 20 minutes or less. Given todays metalurgy and technology, seating rings, wear-in, etc take place almost instantly. The "need" for a 10 hour break-in is probably greatly overstated.1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
03-18-2010, 07:59 PM #9
I think a manual will tell you to do twice as much as is really necessary because people can only be expected to do about half of what they are supposed to do. I think Engine Nut would confirm that the biggest issue is not running at one speed as many people do when they get in a boat. A car's transmission constantly changes engine speed as you drive. With a (more) direct drive as found in a boat, you just don't get that. If you take it easy and vary your RPM's for the first few hours, that would probably do it. Still, who wants to chance it? I'm strictly following the recommendations. Why not?
03-18-2010, 11:05 PM #10Sled491 Guest
I could be wrong on this, but the longevity of your engine has to do with break in. Seating of the rings, bearings etc. Oh sure the engine will run like a banshee out of the box, but without proper break in and the seating of bearings and rings, you could greatly reduce the life span of your engine.
