Results 21 to 30 of 32
03-24-2010, 08:30 PM #21
you don't need a new manifold, but most of these are custom manifolds that have larger diameters to handle increase waterflows from the larger pump(s). If your fill lines are 3/4" and your supply line is 3/4 Manifold, vs a 1" or 1 1/8 or 1 1/4" manifold supply your fill times for multiple bag fill will be significantly increased. its just basic fluid flow dymanics...supply and demand but saying that the flow rate thru the newer valves is higher than the stock sprinler valves.......you should look at Jesse's fill time chart
09 21v LAUNCH
99 Outback LS. Sold
Doug
03-24-2010, 09:00 PM #22
Ah, I wasn't factoring in the bigger diameter of a new pump. I will definitely be getting the Irritrols after seeing Jesse's time chart. Just wanted to make sure I wasn't missing something if I'm not planning on upgrading my pump also.
Thanks for the info.
03-24-2010, 09:13 PM #23
03-24-2010, 11:49 PM #24
Has anyone tried the Irritrols in a newer model boat? I would really like to see the timings before everyone swaps to these. I know they performed better than my stock valves from 2002, but I am still not sure about the newer models.
15 Mondo Surf Edition
02 LSV - Traded In
03-24-2010, 11:55 PM #25
Jesse, when I picked up my boat from the dealer last Friday I noticed the stock manifold was 1" (I didn't install the 1" poly manifold I bought) so I just swapped out one of the Orbit valves that fills one of the 750lb sacs for an Irritrol 3/4" valve. Problem is the next couple days the weather was not great so I didn't get down to the water to test. Then on Monday I took my boat to Earmark to have the stereo system installed. It won't be until next week sometime before I can do an "on water" test. I'm just going to time it filling the 750 sac until water comes out the vent/overflow.
09-11-2010, 12:53 AM #262008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
09-11-2010, 08:02 AM #27
here's a link.
https://forum.moomba.com/showthread....ight=rule+2000A Day at the Lake...Priceless
09-11-2010, 05:23 PM #282008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
09-11-2010, 05:45 PM #29A Day at the Lake...Priceless
09-11-2010, 06:17 PM #30
I wish I knew what method would fill the bags fastest.
Two Rule 2000's or one Rule 3800.2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
