Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    NorCal
    Default Outback V Tsunami upgrade
    Just thought id post this up since there was some question as to weather these pumps would fit in a smaller space. I put a couple differant manifolds togeather just to see how they would work.
    Heres the first one
    06 Outback V
    NorCal
    And the one I decided to go with
    06 Outback V
    NorCal
    And installed
    06 Outback V
    NorCal
    Vented loops
    06 Outback V
    Mar 2008
    Vancouver WA
    Looks snuggish in there! Nice work. Thats a great place for those vents.
    I noticed you have the same interior speakers as me. Nice choice.
    Nice Heiny BTW
    PWI as usual...
    Oct 2009
    Wisconsin
    Tight fit!!! Not easy to work in such a small area. Excellent job!
    Did your boat come stock with GIII? If not, what are you using for drain pumps? Post more pics once you're done
    Very slick. Good use of your space.
    NorCal
    Quote Originally Posted by newty View Post
    Nice Heiny BTW
    Yeah I have 4 of the same but 6X9's on the tower, love them.
    Love the Heiny's too. lol
    06 Outback V
    NorCal
    Quote Originally Posted by 2007 Outback V View Post
    Nope it came with the GI. Im using the stock empty pump for the ski locker sac and Tsunami's for the rear sacs.
    06 Outback V
    Thanks for the pics, just so you (and anyone else that's interested) know, Tsunami pumps with the long inlet use straight thread, so you can cut that down with a hack saw to 3/4" of an inch and it will still thread into your fittngs fine. That makes it a little easier to fit everything into cramped bilge compartments.
    Also, ideally you should use bronze fittings for this application and not brass. Brass will undergo galvanic corrosion at a much faster rate, in fact we've seen brass ball valves fail in less than a year. If it's past the ball valve you can switch to plastic, which will save you quite a bit of weight and money.
    Nice install though, can't wait to see the finished product!
    WakeMAKERS | WakePROPS | WakeSOUNDS | EasyBoatCare
