Results 1 to 10 of 11
    Default Fierah has new Shades on.
    Tinted the window as many had suspected from some previous pictures.
    Also striped all the factory stickers off.
    I got some new customs ones made.
    Heres some pics with it installed.
    Apr 2009
    San Antonio, TX
    looks good. how long did it take you to take the windows off?
    You may all go to Hell, and I will go to Texas.--Davy Crockett
    Apr 2009
    San Antonio, TX
    oh yeah, and what % tint is that?
    Taking them off was a good hour and it takes 2 people for part of it.
    Center window was a snap, push the pins out.
    Side sections, remove the rubber skirting.
    Remove the 2 screws on the ends right by the tower legs.
    Remove the 10 or so screws from the window under that rubber skirting. There is 1 screw on each side mid way up that has a bolt on it that has to be held under the dash and in the cubby respectively. This is a 2 person job.
    Once all the bolts are out, grab by the walk threw and gently lift it up to break the rubber seal to the gel coat. Nothing will tear and crack, its just a pressure seal from the factory install.
    Windshield it really light, maybe 25 or 30lbs a side.
    Then do a lot of shopping around to get the right tint shop. They should be telling you they will take the whole thing apart to tint it correctly.
    I went with 20%
    Mar 2008
    Vancouver WA
    Straight Sexy! I cant wait to get some pics of the ying yang twins together!
    PWI as usual...
    Man, I hate window tint but I love the look. I sure hope it works for you and you're not ready to rip it off after a few times out. It looks like a very professional job.
    Quote Originally Posted by newty View Post
    It will be hot thats for sure bro.
    Have to say a big thanks to Newty, with his help on what to do i was able to pull it apart and not damage anything.
    Thanks man.
    Feb 2008
    Traverse City, MI
    I knew there had to be a thread for this! Looks really good!
    2013 Outback V
    Feb 2009
    Seattle, WA
    sick looking .. nice work.
