Results 1 to 10 of 23
Thread: Air Lift Suspension
03-10-2010, 01:19 PM #1
Air Lift Suspension
I know some of you guys are running the air lift series rear suspension. I just got one of these for Big Blue. It doesn't say in the instruction, do i remove my regular socks all together? Or do the air bags work with the shocks?
Just curious, i wont be doing this install till next weekend.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
03-10-2010, 01:47 PM #2
shocks are not removed, air bags just help level a sagging rear when loaded down.
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
03-10-2010, 02:30 PM #3
Exactly, you don't change a thing but add the brackets, bags and lines. Also remember that if you got the compressor it needs to go in a dry location and not in the engine compartment.
03-10-2010, 07:20 PM #4
Mike, Big Blue doesn't sound that tough when you expose his saggy rear end.
03-10-2010, 10:07 PM #5
03-11-2010, 01:39 AM #6
03-11-2010, 03:38 AM #7
If you don't need the air tank or air horn I'd recommend this. Harbor Freight puts these on sale for $50 and fill a 35" x 12.5" tire from 10psi to 25 psi in about five minutes. Thirty amps so it connects to the battery. jonyb has an excellent setup that I envy with a tank and all.
http://www.harborfreight.com/cpi/cta...emnumber=66399
http://www.discountjeepparts.com/ind...th/909_910_609
http://www.discountjeepparts.com/ind...cPath/909_28691998 Mobius
310 HP PCM
SOLD
03-11-2010, 10:04 AM #8
I already bought the on board system, its ok if its a little slow, I like the idea of the tank and air fitting, i still dont want to have to get a compressor out of the back, plug it in to air the system.
I want a completely stand alone system, this way when i sell the truck in a few more years it will be a true upgrade for some other guy wanting to toe things.
Biggest problem i have, and why i got a air system is my truck sits so high normally i have to stand on the bumper to get the boat on the hitch. Then after the boat is on it sags so low i had to flip the receiver and ball over for a 2inch lift to the trailer would sit level.
Now i can flip my receiver over and have a 2inch drop, this will allow the boat to connect with out standing on the bumper of my truck, then his the air switch to raise the truck to level and the trailer to level.
Even with the boat hooked up my truck still felt solid and rode fine, just hate the ass end looking low LOL.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
03-11-2010, 12:40 PM #9
I have the setup from AirLift Ride Control System with the Load Controiller II gauge/compressor and it works just fine. Has a 0-100 psi rating with the single onboard compressor and gauge. I run it at 5psi (minimum) when unloaded, 30psi when towing and 60psi when towing and the bed loaded with all our camp gear. Will fill to 60psi in about 30 seconds.
Got the whole setup for around $210 shipped, well worth it.2007 Mobius LSV
03-11-2010, 09:52 PM #10
Thanks RAZZ. You just made my list a little longer, but much needed, probably be up there towards the top. Ol' Black has the saggies just like BIG BLUE.
