Results 1 to 10 of 13
Thread: Where to put front vented loop?
03-02-2010, 09:32 PM #1
Just wondering the best spot to stick the front vented loop. Anyone who has gone this route have some suggestions? I'm going with check valves in the rear but need to get a loop for the ski locker. Thanks!
03-02-2010, 09:45 PM #2
Most route it along the inside wall under dash where it will be out of sight to everyone but the driver. So basically if you were sitting in the drivers seat it would be on the outside of your left leg
03-02-2010, 09:53 PM #3
03-02-2010, 09:54 PM #4
Yep, another dang hole
03-02-2010, 09:59 PM #5
why not put the loop in the engine compartment over the vdrive by the ski pylon. No holes.
PWI as usual...
03-02-2010, 10:08 PM #6
I think you want the loop as close to the bag as possible. I was thinking behind the observer seat and expanding the battery cable hole???
03-02-2010, 10:12 PM #7
I wouldnt think that proximity to the bag would make a difference so long as the loop is as high as possible.
PWI as usual...
03-02-2010, 10:17 PM #8
I'm not sure why it matters either, but jasonwm was pretty clear that I needed it up front to work properly.
03-02-2010, 10:33 PM #9
03-02-2010, 11:31 PM #10
I have mine up there. I had to extend the hose so that it will work. Removed both floor boards to run new hose. Works great.
