Results 11 to 20 of 38
02-28-2010, 03:17 PM #11
if you ski gowith the obv , if not go big and xlv... you really can't slalom behind an xlv..
02-28-2010, 06:05 PM #12
One thing to keep in mind, the '08 Ballast fill system is terribly designed, they used Sprinkler valves that should have never been put in a wakeboard boat. The '09 models have a much improved JABSCO pump system that will fill and drain much more efficiently.
Many Supra and Moomba owners with '08 and older boats have had a lot of porblems with the ballast fill systems not working properly and are extremely slow.
Just something to keep in mind... I had to replace my entire fill system on my '08 Supra because of excessive problems with the sprinkler valves. Its not a huge expense, but definitely something you will have to consider.2008 SUPRA Launch 22 SSV
2011 Malibu VLX
2013 Malibu VLX
02-28-2010, 10:29 PM #13Sled491 Guest
You never said what year the boats are. Are they both the same year? The XLV is just simply huge next to an older (0 OBV. I think the 40 on the XLV sounds like a better deal, but only if it is the boat you want, need, or can afford.
03-01-2010, 08:06 AM #14
dont forget to factor in where the boat will sit when not being used-- a xlv wont fit a standard garage
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
03-01-2010, 12:52 PM #15
03-01-2010, 02:05 PM #16
Just my 2 cents...I love the XLV..would never go any smaller. Mainly wakeboard, and surf, and great for when you need the extra room. If you are a hardcore skier, then def go with a smaller boat, but if not, for the extra money and room, you will not be disappointed with the XLV. What ever you choose, make sure to post some pic's of your new purchase. Good Luck!!
2006 Mobius XLV
03-01-2010, 09:21 PM #17
03-01-2010, 09:24 PM #18
They are both NEW 2008... Never registered before and a dealer blow out (so they say).... We cna afford both, but the XLV is stretching the budget to a little more than our original max we wanted to pay.... I just dont want to be looking back and saying, "for an extra $4k I should have".... for the amount of time and years we will have the boat, I think its worth it, but will have to check the specs tomorrow... I will post when I get the email from the dealer.
03-01-2010, 09:25 PM #19
03-01-2010, 09:41 PM #20Sled491 Guest
The 09 / 10 OBV was a completely redesigned OBV. The 08 version is the old hull and was more like the DD Outback but with a V Drive, while the new OBV has a very specific hull design for Wake surfing/boarding. The new hull OBV would be smaller than the 08 you are looking at. The XLV is the Mac Daddy of Moombas and is way bigger, by almost 5 ft in length.
Personally I can't own a V Drive due to limitations on my lake frontage, but if I could, for that money I'd go XLV.
