Results 1 to 6 of 6
Thread: PCV Valve
    Jul 2009
    Spokane, WA
    Default PCV Valve
    So, along the same lines of cleaning the flame arrestor, do any of your guys do anything with the PCV valve? I believe in the manual, it says to either clean/check/replace (I don't have the manual right now, so can't remember which) at 100 hrs. Do any of you guys do anyhting with it? I see that it's probably a fairly cheap thing, so if you do replace it, it won't break the bank. Any thoughts?
    2015 Supra SC400
    08 LSV - Sold
    Go big, or go home.
    Jun 2006
    I have replaced mine at about 500 hrs....they are inexspensive.
    Shake the PVC and if it rattles your good to go. If it doesnt replace it.
    Jan 2010
    Milwaukee, Wi
    I second that.
    08 Outback
    82 American Skier
    Jul 2009
    Spokane, WA
    Done and done. Thanks guys!
    2015 Supra SC400
    08 LSV - Sold
    Go big, or go home.
    Apr 2012
    Quebec, Canada
    Is there 2 PCV valve? When I m in the boat facing the engine on the right side of the engine, near the dip stick, there is a "PCV valve?)connected to a hose that is connected just under the flame arrestor.
    On the left side ( driver side) there is something that looks like the PCV valve. A hose is connected to the valve and directly to the flame arrestor.
    The two valves on the right and left side look almost the same. So which one is the PCV valve?
    Thanks
    Mobius LSV 2011
