    Oct 2005
    Durham, NC
    Default Ballast thru-hull connection
    Okay gang, I have been reading all the post about the ballast upgrade projects and have learned a ton of stuff. I am almost ready to plumb in a proper ballast system into my 2001 Outback DD. I am planning on using areator pumps (Tsunamis), but I am having trouble figuring one thing out. The bronze thru hulls are NPS threads, yet the ball valves that most people seem to use above them all seem to be NPT threads. Then it looks like the standard Tsunami pumps are NPS threads again. How did you guys deal with this?
    Oct 2005
    Durham, NC
    Bueller, Bueller? Anyone?
    Sep 2009
    Copperas Cove, TX
    Maybe you'll get more hits on Wakeworld
    Des Moines, IA
    I'll try to give a more detailed explanation later, but the thru hulls, ball valves, and tsunami 800s should all be the same. The 1200s is where you have to get creative.
    Des Moines, IA
    Sorry I forgot about this thread. Here is the best explanation I've seen on the topic. There are really 2 good options - using a flanged seacock or getting a combination thread thru hull. http://www.jamestowndistributors.com...Valves+-+Groco
