Results 11 to 20 of 21
Thread: Good 2nd Prop?
02-09-2010, 02:12 PM #11
yes but I can past the email in my inbox on here, actualy i cut and past this last one at the begining of my last reply
02-09-2010, 02:15 PM #12
I thoght that you had said 14 x 14 but could not remember for sure so remailed to confirm what it was. i will look in my inbox and tell you who said that, anyhow do you have the part number?
02-09-2010, 02:16 PM #13
odd, you must be eric johnson and this id the email you sent me yesterday, were you talking about vdrives?
02-09-2010, 02:18 PM #14
May be some confusion. I would have suggested a 14.25 X 14 for a wakeboard option, not for a direct drive though. We offer the 14.25 X 14.5, the new prop for 2010, as the wakeboarding option. For a 1:1 you may not see much difference in speed, maybe 1-2 MPH between a 13 X 11, 13 X11.5 or the 13 X 13 4-blade.
Eric Johnson
Johnson Propeller Co., Inc
OJ PROPS 800-359-9730
02-09-2010, 02:21 PM #15
Comment or question
I can not remember what size and what was the best prop to get for top end speed gains, could you give me the part number please. my boat is a 2010 moomba mobius direct drive. thanx again.
Dan,
We typically run our 13 X 11.5 LC 1" 3-blade for max speed.
Thanks,
Eric Johnson
Johnson Propeller
800-359-9730Eric Johnson
02-09-2010, 02:21 PM #16
well I guess i will ask you then, if you wanted low wash atleast 43mph what should i get?
02-09-2010, 02:27 PM #17
I'm assuming you have not run the boat yet. I would suugest to run the boat with the stock 13 X 13 3-blade we supply SC and get a baseline of MPH and RPM. I can suggest a different propeller after going over those numbers.
Eric Johnson
02-09-2010, 02:32 PM #18
i'll get back to you end of march then. and that will you a better idea then, when i do order a prop from you guys do you include a puller kit?
they are hard to find up here
02-09-2010, 03:08 PM #19
We do have pullers and prop kits. We can discuss the details through e-mails.
Eric Johnson
02-10-2010, 12:38 AM #20
Eric,
I'll probably contact you through email as well. I've got some questions on my particular applicaiton
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
