Results 11 to 20 of 20
Thread: GI to GIII Simer pump upgrade
09-19-2010, 12:23 PM #11
Thanks, it is a solid system. I used it all summer flawlessly, although I have found a few tweaks that I plan on making. Let me know if you go this route and I'll throw a few more ideas your way.
No, I did not add any additional intakes. All three pumps utilize the stock intake with custom manifold. I am planning on adding an addition intake or two.
A simer pump could be mounted in the ski locker, the pump would have no problem drawing water. The ski locker is a tight place in our boats and the simer pump is at least two times the size of the stock rule empty pump. However, I never really tried fitting it in there. Could be done.
Good luck, and glad you like the setup.
09-19-2010, 12:31 PM #12
So how long does it take to fill the bags compared to before?
2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
09-20-2010, 12:44 PM #13
I think he said 8 or 9 minutes and that's with the stock intake valve and 3 pumps! (if I am reading this right). Got your PM Chad, sorry you haven't been feeling well.
I guess the other option for the third and fourth pump (my plan is to do a seperate pump for the integrated bow sac) would be to mount them beside the rear pumps under the seats and then run the hoses forward under the floor to the Center and IBS.
T100 posted a thread showing a guy who used the Johnson pumps in his Centurion and he had fabricated a Tee fitting into his rear lines so that he could fill bags that would be situated in the seating area and still be able to drain them off of the same pump: http://www.centurionavalancheballast...l.blogspot.com
So, my current plan of attack is to:
- Remove the stock intake and upgrade it to 1-1/2"
- Add an additional 1-1/2" intake
- Run 2 pumps per intake via a Tee fitting
- T-Fitting off of the fill/drain hose on the rear bags with PVC Ball Valves on each line.
Haven't decided if I will use Simer or Johnson pumps. The Johnson pumps are pricey but at least they are ignition protected and allows me the option of putting them down in bilge area. Heck, you could probably go 2 Simer and 2 Johnson if you needed to save some cash.2011 President's Trophy - Check
2007 Outback V
09-21-2010, 10:47 PM #14
Yup, you got it, about 8 to 9 minutes. Also, thanks for your concern, I am feeling much better now.
Why 1.5" intake? I think a 1" mushroom intake for two pumps will supply plenty of water, plus then you don't have to put those monster holes in the hull? I may be wrong, let me know.
Funny you mention the Johnson pumps, I plan on getting two and putting them in the bilge/engine area (not sure on placement yet). 2 pumps per intake is my plan as well, but why the PVC ball valve on the rear bags?
This ballast stuff is fun, isn't it!
09-22-2010, 11:48 AM #15Why 1.5" intake? I think a 1" mushroom intake for two pumps will supply plenty of water, plus then you don't have to put those monster holes in the hull? I may be wrong, let me know.
Why the PVC ball valve on the rear bags?
I'll definintely do my best to document my install and post it. So, do you think you'll order in a couple of Johnson Pumps then? And, do you think you could fit 2 Simer pumps side by side under the seats where you have them now?2011 President's Trophy - Check
2007 Outback V
09-22-2010, 08:41 PM #16
09-23-2010, 05:02 PM #17
Hey, where did you get your check / one way valves?
2007 Outback V
09-23-2010, 05:44 PM #18Senior Member
- Aug 2008
- Cottage Grove, MN
- 780
Stupid question, but what does it mean for the pump to be ignition protected?
2006 Outback V - Gone
2008 LSV - Gone
2013 other brand
09-23-2010, 06:37 PM #192011 President's Trophy - Check
2007 Outback V
09-23-2010, 08:37 PM #20
