How did you have the access points done?
Had a local upholstery shop cut slits over the cleats and install a heavy duty zipper like what Cory uses. Then above the slit on the inside he sowed a flap of the thick gray padding, when the access is close the padding is down protecting the boat from the zipper and when we use the access point for the cleats we just fold the padding out of the way.
