Does anyone know what the amp rating is for the dash switches? Would they be able to run 10 amp without a relay?
So I opted for the Lumitec Seablaze X2 Full Spectrum lights. Got them on the back of the boat, just need to wire them up and test them out. Advertised at 6000 lumens each...should be adequate for our swamp water.
https://uploads.tapatalk-cdn.com/201...8a80062d7f.jpghttps://uploads.tapatalk-cdn.com/201...ec57854a9d.jpghttps://uploads.tapatalk-cdn.com/201...69b929de32.jpg
Nice install, be sure to post some pics of them in action!
Got them wired up and on. Now all that’s left is Lake testing. https://uploads.tapatalk-cdn.com/201...92751987d2.jpghttps://uploads.tapatalk-cdn.com/201...92246dd0bd.jpghttps://uploads.tapatalk-cdn.com/201...e315bf4ff7.jpg
I’ll have to find the link from the forum, but someone mentioned a $40 amazon boat plug light... I wired it to my courtesy lights and am impressed so far!
https://uploads.tapatalk-cdn.com/201...26c2552cf8.jpg
I installed the "Firewatermarine Super Delux 10 WATT Garboard Brass Boat Plug Light 1000-1200 LUMENS", $25 at amazon. The light doesn't blow you away, but it's great for the price. I did have to put a bunch of pipe tape on the threads to keep the plug from bottoming out though (either plug too short, or threads dia too small), so probably not ideal if you have to pull the plug often. Install was a quick crimp, since power was already there. The stock (2017 Helix) toggle switch for underwater lights is 3 amps. You could run higher amperage lights off the heater toggle (15 amps) or docking lights (10 amps).
Has anyone tried the THE QUASAR 2.0 Boat plug light from (LOW PROFILE OFFSET) with the 1/2" NPT EXTENSION?
