These are all my issues too. Can anyone help us?
Just spoke to several sources, including wake makers, and they say that a thicker board with more float is the answer-- I think I am going to go with the o'brien haze. Alternatives that are similar are the ronix marshmallow and the obriens celsius
I have an XLV with Sumo 900's run about 11.0 MPH surf with CWB ride. Everyone that has been behind my boat with any balance can free ride. The wake should not be the issue, could be a combination of skill level with the board as wake makers says. We are actually bored with the CWB ride and would like to get a couple of new boards. I have no idea what to buy as far as a different board. The CWB ride has been a great board to get up and free ride on though.
Try putting the wake plate all the way up and you need more weight in the boat. Think of it like this... More boat in the water (sitting deeper) the stronger the push will be behind the curl (wave) that comes off the back of the boat...
You can't just put tons of weight in the back corner and expect a great wave.
You have to have weight in the front of the boat to keep the bow down in the water. It also helps to have weight along the surf side to give the boat a good lean for the curl...
One last thing, it helps to have weight in the back of the non surf side. This helps keep more of the boat down in the water.
Hope this helps
You have plenty of weight. Board may be part of it.
But '8-11mph' is a pretty big range. Small increments can have a big impact on your wave.
Any video available?
With the 1100 back there you likely need more in the front. I'd also start with the wake plate all the way up. Also, I wouldn't start at 8, I'd start at 12 to get the boat moving and wake formed up. Then slowly back your speed down while watching the wake (with no one surfing) about 0.5 mph at a time. At some point you should see the wave clean up and get real pretty. May want to check your speed with a gps app on your phone.
2 things:
1. local shop has an inland surfer demo that looks like it has never seen water. thick buoyant board. any opinions on inland surfer brand and a real fiberglass/wood board?
and, completely off topic:
2. I continually see people trailering their boats with their boards in the racks. is this ok, even though the owners manual says not to do it? i have the factory racks.
Inland Surfer boards are great, IMO. Which model is it?
You should NEVER leave boards (surf or wake) in the racks when the boat is on the trailer! Not only can you damage the boards, but you may have one heck of a lawsuit on your hands if/when one flies into traffic.
inland surfer red rocket
I weigh 235
