Good to know, I'll definitely be doing this as well, that carpet back there is a real pain in the arse.
Is this stuff too strong? I don't want to burn through my hull like the acid in aliens.
http://i.imgur.com/LrqbBoGl.jpg
I'm redoing my floor with Hydro Turf and bought the same thing to get the glue off. So far I've used it on wood, aluminum, and fiberglass and it doesn't hurt the surface at all. But does take some elbow grease to get the gule off.
But it was only $19 at my HomeDepot
Canadian pricing..
haven't decided about doing the sides yet..
about an hours work scraping with my tanto blade knife and some soapy water later left me with this..
http://i.imgur.com/kkdvGT9l.jpghttp://i.imgur.com/N8on398l.jpg
I just want to note, QC at Moomba's factory is shit... the plastic boards that protect the locker from the engine.. the screws were put in so crooked, they stick out the side...
pictures tomorrow.
Quality work by Skiers Choice right here.. all of the boards had screws the same way.. I sure hope the guys who do this work aren't the ones who put the rest of the boat together.
http://i.imgur.com/OYWCE9ol.jpg
since the just did the floor on mine for now, anyone have any advice on a good carpet glue to stick the wall carpet back on decently? nothing too messy, in case i want to remove it and bed liner the sides later.
3M spray adhesive
x2^^ 3M Super 77
make sure you spray the side wall and spray the carpet. Then be sure to wait 30 seconds to a minute before sticking the two together. I like to use a j-roller .
http://www.lowes.com/pd_290286-16878...ductId=3030691
couple of complaints, the rear dividers are no longer long enough to reach because of the removal of the carpet thickness, so i needed to use some thin rubber i have laying around... and the fiberglass is absolutely garbage in the moomba in the rear locker floor... had to drill new holes and they still spun and won't hold..
i've dedicated a bit more time to this since out of storage... i've removed all carpeting in the rear storage lockers... still need to remove the glue from the walls..goo gone wasn't working for me.. will stop by store tonight and look for something better
