Trailer axle bearing / seal leaking?
Quote:
Originally Posted by
slipperyrockTKE300
sometimes I think we all see the wrong pdf instructions for our trailer hubs. I came across two that are very similar.
Ours are not pressurized - other than the lube being forced into the bearings and trapped until a slight oozing appears on the front bearing, and then the cap squeezes the grease back in.
I'm not so sure that the spring loaded cap will allow for a zerk fitting to work. Not saying it won't, but after seeing how it operates, not sure it will. There is a mechanism inside the cap that spins and it may keep grease from getting to the bearings.
The zirk fitting - (a new one comes with the rebuild kit) is located under the cap
Can you show a picture of where this zerk fitting is?
Sent from my iPhone
