Correct size = measurements, then I can draw in CAD. A CNC is a computer controlled cutter. Think of a milling machine with a large flat bed and a hand router moving in XY and Z
Ok, here are the measurements, I hope this is what you need. Let me know if you have any questions. I would cut on the side of being a tiny bit big so you can trim/sand it down to fit.
That came out great! I want one! Patrick if you can cut some out I will gladly pay you!
Scott, where can I find that cap rail???
Sent from my iPhone
David, I actually have an extra piece I am happy to send you. Pm me your info and I will mail it out.
Wow that looks great. I will have to put one together for mine but much shorter.
That end cap material can be found at http://www.mcmaster.com/#standard-plastic-trim/=oqxrhf
Check out the Style 2. If that doesn't do it mcmaster.com usally has something there you just have to look. 25ft. min but if you are making them for others that won't matter.
I'm in for one as well
used it tonight up at the lake and it works great. No movement at all and no air coming through. It seals off really nice.
