Think this would work on a 04 LSV? I know the seat is different.
Sorry, I don't have pictures. I did this recently on my 06 LSV, I know they are different. My rails were getting all corroded and nasty so I took them out last year and was trying to figure out that to put there. I found a simple locking swivel base and just used the swivel bolted to the boat, had to drill new holes and then that is mounted to the seat, also had to drill new holes. It has not been lake tested and it actually hits the side wall so it does not swivel much unless you turn towards the wall and still does not go all the way around. This is not as easy of a mod as I was thinking it would be. I might have to follow the example above and pickup a couple plates to spread the weight more on the seat.
My seat ended up a little higher when I did mine so I don't have to use the bolster. Another nice feature.
