Re: Water trapped between hull and ski locker subfloor
Once you have a wet slip you'll never remember the inside being dry..lol...
Quote:
Originally Posted by
parrothd
parrothd
What exactly are you talking about here?....
The inside/bilge of my boat always has standing water (4-12 inches). I'm in a wet slip 5-6 months, then rain and snow while in storage. If you have mildew on the seats you should add vents to the cover.
Skier's choice isn't too concerned because it's not hurting anything and there's really no impact. The dealer on the other hand sees $$$ out of your pocket. ;)
If you cut holes in the rear sections you'd find water and soaked foam as well, just the nature of boats. Just think you guys are over worrying. :)
parrothd
Not when other boats are designed never to have this issue.
SC is gambling that the fiberglass, gelcoat and foam won't fail during the first ownership. It will eventually fail.
There's a reason boats newer boat don't use wood stingers, anymore. They used rot and you'd have to replace them. It's the first thing you need to check on an older boat. Fiberglass isn't going to rot, or gelcoat blistering with the usage type you have. :)
