2008 Mobius xlv - Help! No Power to Ignition Switch
First time for me posting here and all replies are appreciated. Today was the first time in the water since winterization. The batteries are fully charged and all powered switches (ie. horn, stereo, blower, ballast) are working normally. I turned the ignition to start and get nothing - no beep, no engine light. With a volt meter I check for power coming to the ignition switch - 0 volts (I believe it's a red wire with blue stripe.) I go to the fuse panel and change out the 10amp fuse for the ignition with a new one - still no power to switch. I then remove the fuse and check for power across the circuit - 0 volts. All other circuits on that fuse panel have power. Does anyone have any other ideas? I tried the usual remedies like playing with the throttle to make sure its in neutral, and I connected the kill switch circuit with a jump wire but still nothing.
