Yeah, this issue was discovered by people placing check valves on the vent line for the IBS/center hard tank. Resulted in some busted center tanks.
Oh that's a bummer. Good catch, I'd never want to do it, so had no idea. Then maybe a manual pump over the side and the bag not plumbed in?
Read though this a few times and thought I understood it all. Got my pitch and roll set to surf goofy at 9 and 3. put more people on the starboard side and auto wake keeps dumping the bag on the starboard side. Why is that? I fill all bags to 100% manually and turn auto wake on when I am getting in the water. The wave is good and has push but it just doesn't make sense to me that it is dumping the surf side and is not asking to move weight either.
It's working as it should, you have the roll set to 3 and you have more roll than 3 degrees, it's dumping surfing side ballast to get back to the 3 degree roll. Use the default values for the roll, I think it's 5?
Move people to the port side, autowake can then drain that side. But really you want to have 5 roll. It only tells you to move weight when the side its trying to adjust is at 100 or less than 80%.
Best to fill up to 100%, turn on autowake and get up to surf speed, then check the pit/roll and move people to help obtain the desire pitch roll while moving. You get max ballast that way.
Goofy really needs to be around 5°.
OK, for some reason I thought I read 3 and -3 for port. I will try 5. I guess when goose was saying to Maximize the weight by putting more people on the surf side. It dumps it out to around 70% on the surf side.
It will dump from the surf side if you have MORE roll than the setting in Autowake. Because of prop rotation the roll to the left for Natural footers will always be less than the roll to the left for Goofy footers.
I find -3.5° for Natural and 5° for Goofy.
Pay attention to the positive and negative values. -ve is roll to port/left and +ve is roll to starboard/ right.
