Beejwest
I understand your concerns with the 1100 rear and ski locker bag and now wanting the IBS.
Problem 1 is you are prolly going a bit to slow in the boat.
Along with your heave rear bag set up and tall rampy wave, if you speed the boat up it will also add length to your wave, and that Pocket will get pushed back into the wave as well allowing you to have more push farther back.
2nd issue is the LQ Fish is a slower board for beginners, with a lighter faster board you will be able to surf better with your current setup. With the Fish you cant pump the board or work it back into the wave. its designed to just let you cruise and be forgiving of your mistakes as a newer rider.
Ninedriver when I had my 08 LSV we ran 1100 port, 300 ish star, ski locker and IBS and had a really nice wave at 11 mph. I want to say the tach read around 3300rpm.
I removed the cooler and tried a sac under it but i didn't like how the main panel was flexing under the weight. There is no bracing from your side panel to the floor under the cooler like the rest of the seating area.
