Has anyone changed the impeller on this motor? It seems impossible!
What boat? Typically you remove surf locker inner engine cover and the impeller housing is super easy to access.
I figured an SE550 from your name, so pull inner surf locker and it will be a piece of cake for ya....
https://uploads.tapatalk-cdn.com/202...3c45d2350c.jpg
Yes—you end up taking it from behind.....[emoji2373][emoji6]
The 550/575 has a more complex cooler mounted in front of the engine that blocks access to the housing. Access is extremely tight.
I worry that it would not be possible to do on the water in an emergency. Any boat movement would create chaos.
