Mike, what boat do you have. I'm wondering if this prop will give me the same results in my craz.
2016 Moomba Craz
Gunmetal W/ flake
Atomic Orange Accent
Black Deck and Hull
2016 Moomba Craz
Gunmetal W/ flake
Black Deck and Hull
I didn't check the date on this thread, wondering what was up. He sold the prop in this forum. I'm assuming because he sold the boat.
I ran the 1617 in my LSV, and it was a beast. It ran 1 1,110 bag fine along with the center, ibs, and an extra 400 lbs, but I think running 2 1,100s at the same time would've been too much. The engine just didn't have enough power to do all of that.
I pulled the 1617 off the LSV when I traded it, and will use it as a weekend saver prop only. I called Wakemakers and they approved of it for that. For the mojo & craz, I believe the Acme 1235 or 2079 would be the ideal replacements
https://www.wakemakers.com/moomba-wa...oat-propellers
Hmm 6.2 beast might handle it okay
2016 Moomba Craz
Gunmetal W/ flake
Black Deck and Hull
Just in case you don't see the prop thread in the general section from today, I'll post her as well.
I swapped the 1235 to a 2079 over the winter and it's night-and-day different. I'm running 3,000 - 3,400 of ballast and have no issues planning out. Last fall I had trouble with the 1235. Lose a couple mph on the top end, but I'll take that all day long over having issues planning out.
Hey guys, yes this was the LSV thread when I went to 1617 and its an awesome prop on the LSV. I sold that prop because I sold the boat, and on the Mojo I can run a better prop then the 1617.
On the Mojo I run the 2079 and its a beast as well. I responded on 07STI thread about that.
Another vote for the 2079 I have a 1235 and went to that. Hands down worth it!
Sent from my SM-G935R4 using Tapatalk
Can't wait for my larger bags to really test out this OJ945 (15"x13p) at wake speeds and a boat load with full gas. I was thinking that I might have to up to the 2315 (15"x12p) and see what the RPM's do there. Will be out for the holiday weekend to really get numbers since I have lead that will act in having bigger bags in the rear. For the life of me I can't remember what RPM's are at with wake speeds with my current setup.
Hope to get a chance to learn this wake over the weekend...
Attachment 24218
I just tried tried the 1617 with horrible results. I've been running the 1847 and quite happy with it. Based on the reviews I've read here I thought I needed to try this thing. Ran great with zero weight. However, once the ballasts were filled 1900#'s I could barely get the boat to 10mph. Full throttle, 3400 rpms and maybe 12 mph. Couldn't even get the boat to plane. Needless to say it getting shipped back asap.
