Has anyone installed heat in the 17 Craz yet? Have a pretty good idea but am looking for some pic's on where to mount the heater coil and run the fluid lines. Has anyone mounted it on the drivers side?
I have a 16 that was installed at the dealer. One thing they did wrong they mounted the heater box behind the sub on the floor and ever time I filled the bow sac it would collapse the vent hose . They ended up mounting it above the sub so everything was out of the way and it's fine now. Also make sure you use elbows coming off the back of the engine they made a big loop in the hose and once it got hot the hose kinked and the heat wouldn't work
Thanks, so they mounted it in the bow. Do you have an inline circulating pump? Where do your vent hoses come out?
I can take a video .but I won't be up north until next weekend
