Please help! How do you tell if the boat is an outback lsv or möbius lsv?!
I purchased a 2006 Moomba boat that was advertised as a Möbius LSV. On our first trip to the lake we noticed the coast guard sticker in the boat said 10 seating capacity and the type of boat as an Outback V. We measured the boat and it is 21'6"...the Outback V is listed on the manufactures specs at 20'8" Does anyone have any insight into this situation?!
Re: Please help! How do you tell if the boat is an outback lsv or möbius lsv?!
I think the first 3 or 4 digits of your hull id shed light on this but I dont remember the nomenclature. Email skiers choice will be the best bet.
2006 was probably one of the most confusing years for the Moomba lineup as the 2005 LSV hull became the Outback V and there were different packages such as Möbius that were added to designate the wakeboard boats.
Where are you taking your measurements? You should be going bow to stern, not including the swim platform. If so, you have the right length for a Möbius LSV at 21'6" but I'm struggling with the thought the factory put the wrong I.D. plate on the boat. But, in 2006, they were cranking them out!
You can check some numbers against the stat sheets here:
http://www.moomba.com/downloads/owne.../moomba_06.pdf
If that doesn't clear it up, email your hull number to customer service.
