Acme 1235 Prop for Sale. Only used 1/2 a season on my 08 XLV. Mint condition. Not a single nick or ding. Like new.
Asking $425 obo + Actual Shipping (Probably around 25-30 bucks).
Thanks.
Attachment 18116Attachment 18117
Thanks.
Hmmm, is this too much prop for my 06 LSV I wonder? I totally missed the 1433 on here that Nate just bought, and now I see this...
I think this is very similar to the 1433. I believe the only difference is the 1235 is a little larger.
A search should turn up rather or not it fits the 06 lsv. I'm sure others have done the upgrade.
Yeah when I looked up specs on wakemakers it's half an inch bigger (I'm assuming it's inches)...not sure if that's diameter or radius. It's 14.5 instead of 14. Pitch is the same.
Sorry, I should have had more info in there. Here are the specs:
Acme 1235 4 Blade Propeller 14.5 x 14.25 LH 1 1/8 Bore .105 CUP
The Acme 1235 propeller is perfect for boats running at high elevations or when using 2000 or 3000 lbs. of ballast. Acme Propellers are precision machined and have revolutionized the propeller manufacturing industry.
And yes, it should fit on an LSV.
Where the **** were all these props last year
I'm running one on my 05 LSV absolutely awesome... total stump puller! we mainly surf now so its perfect
from Muh droid .....
Sweet prop just make sure you have the trailer clearance onthe earlier models
Ok I'll consider it, PM sent!
It will work great on an 06 LSV if you run heavy. I would shim your trailer bunks to get a safe level of clearance but other than that you should be good to go.
I surf with my 1100 full in rear left and 400 in front, then as many people as I can get. I wakeboard with about 500 in each rear locker and 400 up front and as many people. It chugs with any more weight than that while wakeboarding, but I know I don't have enough weight up front either.
That sounds like a good match for this prop if you aren't worried about your top speed.
Unrelated, but next time you're out wakeboarding move as many heavy people to the bow as you can, and bring the wake plate up to half and see what you think.
I can put my wakeplate down to just plane out and I do that while I'm driving if I need to, but I don't like to trust other people to do it and then set it back to the correct position for me once under way. I made new hand signals for wakeplate adjustment though lol. I've been messing with it some, and I like it about 3/4 the way up at 25mph and 65' line. I shortened from 70' behind my Supra, I think the LSV wake is wider.
I know I need a bow sack. When I first got the 650lb bag from Nate I filled it all the way up and made my 1100 have about the same weight. My wife was driving with just our two little kids in the boat. It took forever to plane out, but again she doesn't know well enoguh to trim down then back up. I have a tough time finding a third, let alone enough people where I can move them around as needed. With my old boat I've wakeboarded with like 10 people in the boat before, then it's easy to move people where I want them.
Sorry to hijack your for sale thread OP.
501 - What prop are you switching too?
Sent from my Droid Charge using Tapatalk 2
He switched boats .....
http://www.wakeworld.com/uploads_use...5785/12502.jpg
..... so probably something made of gold :p j/k.
I can't believe this thing isn't sold. Good upgrade from the factory prop.
Ya, I still have this prop left over from my XLV, I kept it when I sold the boat because it was like new. It is an awesome prop for any of the newer Moombas. Very good for a weighted boat. I am actually selling it because I ordered a new prop for my MC, ( a very aggressive 15x12 for pulling a LOT of weight) and the new prop was almost $700 so just trying to recoup some of my costs. Oh, and KG, I may be onto a 2013 now :) I do still miss my Moomba though and spend almost half my time riding on Gesepi's mojo which I love. Hope you don't mind a few pics.
Attachment 18237Attachment 18238Attachment 18239Attachment 18240
wow those trailer lights are sweet!
Prop is still available. I did the LED's with some that I found on Ebay. Very cheap project. I have a lot of photos of them.
Hi Rsinger, I sent you a text, not sure if you got it. Sorry it took me so long to reply.
Prop is still for sale.
Never got the text. Found out your prop is TOO big. Already raised my bunks once. Ended up buying new.
No worries rsinger, thanks for checking out the prop.
Levi, I sent you a PM.
Thanks sent you one right back. My friend has the exact same prop on his Mojo and it's a beast. Very good at keeping the RMP's low too, we call his Mojo the "Prius" because it's so good on gas.
Sold! Thanks Levi.
Post #28 states its sold 07220
sent from Apple's competitor via tapatalk 4
