1100 lbs bags and other ballast questions for surfing
Just purchased a 2012 Mobius LSV and have spent way too much time on the forums looking around instead of working, but they have been great and very helpful. However, I have a few specific questions I wanted to throw out to you all for some guidance.
First, looks like I need to upgrade the rear ballast from the standard in the GIII. I emailed wakemakers.com and they confirmed the 1100 lbs sacks will fit into the real lockers and should be plug and play with the adapter they are sending but just wanted to confirm with you all.
I also want to upgrade the center locker ballast though the pump isn't working right now (hopefully just a fuse but will take troubleshooting tips. On the screen it looks like it is pumping but don't hear the pump switching on). WM said an 800 lb tsunami bag will fit with some adapters and again just want to make sure from those that have done the upgrade.
Finally, when looking at a lot of the posts people mention how much in the locker ballast but then say "500 IBS". Like I said I'm a newbie so not sure what that stands for but guessing "in bow seat". If not would like to know what it is. If it is, is it just a sac sitting on the seat and have to use an external pump to fill and drain?
Sorry for all of the questions and certainly appreciate any guidance. Looking forward to lots of memories on the the Moomba!
