1 Attachment(s)
Center Sundeck Latch Coming Loose
I couldnt find the post about the latch coming loose so I started a new thread. I found the problem with this today and fixed it. For the boat owners out thier, before this becomes a issue you may want to change this yourself. Just loosen the bottom nut on the latch , if its still thier and remove the 1st star washer and replace it with a 3/8 lock washer.What i found was even if the nut feels tight you can move the latch back and forth very little and it breaks the nuts loose. So by adding a 3/8 lock washer this will not break loose. Hope this info helps out someone, if not sorry i wasted your time reading this post.
