Okay, so what I am hearing is the outlet needs to be close to or on top of the pump body, but point in more or less a horizontal position? Am I reading those comments right guys? If so, then yes, I certainly have then in the wrong spot!
Squeeg-
I had mounted mine like this which I learned was the exact opposite of what you want.
http://i326.photobucket.com/albums/k...V/P1070275.jpg
Rotated the pump body180 so the line is now coming off the top, still heading past the engine in the same direction, and have had minimal if any problems since then.
Solid, thanks guys. The more I think about it, the more I am sure that I have the pumps sitting identical to the original rule pumps - inlet is pointing stright up, and outlet is horizontal, but at the lowest point (I reused the factory pump mounts).
So, yesm, certainly in the wrong orientation. I appreciate you guys' help. Now I just need to figure out where I want to move them to.
