Winterizing a 2008 340 Indmar
So I have a couple of questions:
If I run my boat up to temp and drain the water from the Muffler, exhaust hoses, 2 block drains, does that get all the water out? I would like to then run antifreeze through it but I am afraid it will cool off at that point and the thermostat will be closed?
I have had a couple of my neighbors tell me they just run their boat up to temp and then immediately switch to 5 gallons of antifreeze and call it good, that seems a little risky to me?
Any advice welcome as I want to do this myself, last year my dealer charged me $350 to winterize and I thought that was way to much after I had already changed the oil!
^^x2. Me as well. Drain it all. Push air thru ballast lines and call it winterized. I also shop vac all the water out so that any water in engine compartment is gone as well.
