Wake makers offers a install kit for the IBS bag(Moomba Piggyback Front Factory Ballast Upgrade (2013-2014)) has anyone tried this and if so was it total plug and play
2013 Moomba LSV
2013 Moomba LSV
Just installed this on my Mondo yesterday. I am actually cruising the forum looking for a few instructions for adding a check valve. The kit didn't come with one and from what I have been reading it helps with draining the IBS completely flat. It works ok but the IBS had a little water left in it after it went through the empty cycle.
The install was pretty straight forward. It was a little tough working in that small compartment under the helm. Because of the small work areas, I ended up cutting the pipe's a couple of times because I didn't want to go too short the first go around.
Attachment 19954
I just did mine as well, was pretty simple. Getting the fittings on the lines is a bit of a chore but from start to finish it will take you less than 20 minutes.
I've not had the chance to try mine out yet but the guys at wakemakers said a check valve isn't needed. It would help empty the bag some but it would also slow down the emptying a great deal.
The plug and play kits for the rear also work great, I installed the 900's in my Mojo.
Have not had mine out to test yet :( Wakemakers said they are really about the same as the 1100's in that space so I'm sure they'll flex the walls and they'll need some beefing up.
