Murder Max Mods
https://r.tapatalk.com/shareLink?sha...8&share_type=t
Here’s how I’m doing mine
Interested in pics of the Supra’s that hinge towards the bow if anyone has some?
Murder Max Mods
I added some heavy duty outdoor velcro to my seats to stop them from flying out when traveling. Simple and cheap insurance since I trailer without my cover to prevent the top rail of my black boat from wearing.
I copied this and completed the install today. So far I am happy with it and feel that I can access the boards that I store under the side seats. I even added a pull strap.
https://uploads.tapatalk-cdn.com/201...acdfaa3936.jpghttps://uploads.tapatalk-cdn.com/201...b2c40354bd.jpghttps://uploads.tapatalk-cdn.com/201...55407c2684.jpg
Nice! I like the strap idea, I’ll have to do the same.
Sneak peak at another mod I’m working on:
https://uploads.tapatalk-cdn.com/201...646173fb4a.jpg
Thanks, I figured this way I can store some stuff in there and not have to rearrange or check on it when filling the 720’s.
The fiberglass in the area circled below is very thin (I though I had a short enough screw but ended up popping up the gel slightly in the first hole, so I ended up using jb water weld along with a screw barely in the fiberglass to hold the plastic clips on that side. On the other side I went down a few inches to give a little more space and used a screw to hold them to the seat base (vertical wall - much thicker fiberglass) instead of the underside.
https://uploads.tapatalk-cdn.com/201...884bcc9a17.jpg
The net wasn’t quite as wide as I liked so I used some zip ties to make it sit right in the middle and also reduce the tension. It’s still removes the same, no need to cut the zip ties as they just slide over the plastic clips/hooks like the net would without them.
Tip: use a drill, not an impact driver to put screws in fiberglass. The impact spins so fast the screw acts as a drill bit and never bites, but does leave a hole lol.
