Auto Flow 2.0 Upgrade on '15 Mondo
Well just came back from our first time out with the Auto Flow 2.0 upgrade on our 2015 Mondo. All I can say it was worth every penny and certainly a noticeable improvement in height and length. We had to play with the settings and make changes from the previous settings. With two of us in the boat and surfing the port side here was our settings:
Port Ballast full (at 850 pounds)
Starboard Ballast (at 450 pounds; 1/2 full)
Center ballast built in tank full
Starboard surf tab at 75%
Port surf tab at 30%
Wakeplate at 1/2 way.
You can play with the wake plate; for us all the way up produced a slightly longer wave. Halfway down produced a slightly taller wave with a little bit more push. The wakeplate position is an 'either or' scenario. Wind and surfer weight would dictate the position.
Finally we had a full tank of fuel.
Hopefully this helps some and dispels any 'myths' out there that the Mondo does not produce a good surf wave. All you have to do is play around with the settings and be very patient.
Pictures to follow.
