Hi,
2002 Moomba Outback LSV
Keep blowing a 15amp fuse when starting and boat won't start. Will replace fuse boat will start but on next start fuse blows again.
Any help would be appreciated.
Thank you
Hi,
Thank you
Need to find the short/over current on that 15A circuit. What fuse is blowing and when does it blow - when in RUN or CRANK?
Crank, once it is running seems to be fine.
It is one of the 3-15A fuses that are together in there own harness. I'm assuming it has to do with fuel pump maybe.
When you say will not start do you mean turns over but will not run or engine will not turn over once fuse blows?
It blows when in crank
