Time to measure the garage door and see if it is even possible.
When I used to store my '08 in the garage I had an 8" drop hitch... the tower would clear by 1/2"
Thanks yall for all the help. I am going to drive back up there this weekend, and try lowering the hitch a few inches off ground and unlatching garage door and rolling it back. If I need to let air out of tires. I was still a little confused when a couple people on here were saying the mirror was the highest point on the trailer. The pivot point on the tower where it folds in the highest point on this boat by far. If it was the mirror I would just take it off all together. When I go back up there though, I will post pics of it hopefully in the garage ha.
When folded, my mirror attached to the arm mounted to the tower was the highest point, then the tines on a wakeboard rack on one side but not the other (go figure), then the tower itself at the hinge. All within an inch or so of each other though.
This pic shows the first night after we brought it home. Didn't have the mirror arm on it yet. But, we got it through that door by lowering her all the way down on the jack.
https://forum.moomba.com/attachment....1&d=1268459786
I plan on buying a drop hitch but right now I lower the tongue onto a skateboard. It was sketchy the first time I tried it. I do use a block of wood to spread out the load on the skateboard.
Post a pic of that! 10" drop hitch at harbor freight was like $28, easy reassurance. I even started towing with it rather than switching hitches all the time but I am only traveling 10 mins to the lake so it's not bad and I have seen nor heard any problems since.
Remove the wheels asks place the axles oncar dolleys.
If anyone needs one I have an 8in drop hitch that I got from harbor freight. Found out I only needed 4 to make it fit. If anyone needs one make me an offer!!
