Originally Posted by
TXSurf4
Yes the % is based on time the pumps have been running vs the timer on that switch. So if you have the timer for your Port Fill at 8 minutes and it has run for 8 mins then it will show 100% regardless of the level of the bag. This is why getting your fill and times correct is important. That being said there is a little dot next to each % when the dot is RED it means that the sensor is seeing water and that the bag is actually full that is unless you have the upgraded bags and your sensor has not been relocated to a higher location. Unless thing have changed the sensor for each rear bags is located on a pipe that is mounted vertically behind the rear wall in each locker. The height of the sensor is located right at the top of the factory bag so when your bag is full there is a column of water in the tube at the same height and the sensor see it and shuts your pumps off and turn the little dot on your screen red. This is why I ask if your dealer relocated your sensors. If they didn't and just added 1.5 min, the the sensor will see water at the old full level and shut the pumps off and show 100% but upgraded bags wont be full. My guess is if you still have your rear bins then they are not filling all the way, the only real storage you can get out of the rear locker with the upgraded bags is by hanging a net in them to hold a life jacket or 2.
