I sure wished they would start pre wiring from the factory as well. Im running 4 rev8 and it was a pita
I'm doing the 4 XM9s tomorrow. Finishing my amp board now... Waiting for carpet glue to dry
Awesome get plenty of pics!
It took me a while to figure it out after I drilled my holes yesterday, but I found a fairly easy way to run the wire in the tubes. I used my fish tape to run a real heavy test fishing line from the bottom to the top. When the tape was past my drilled hole, I would grab the fishing line with a hook from this kit (http://www.lowes.com/ProductDisplay?productId=50158911 I had just happened to buy the kit earlier in the day because I needed an awl). I would then cut the line and tie it off. Next, I would repeat jumping from hole to hole. Once all the fishing line was run, I pulled the wire.
You can see here where my wires all exited the tube. I used the larger pre drilled hole on the right to connect 3 out of the 4 speakers to the main run.
http://www.smugmug.com/photos/i-Zr6h...-Zr6hKMk-L.jpg
What is with the group of wires just above the driver's seat?
I used the larger hole where the grommet is to tie them all together.
The cable is a 4 conductor, so in that bunch, there are 4 leads.
1 is the main feed, 2 are for the right speakers, and the other is for the left speaker on the rear crossbar. The far left lead you see goes down the tower, and will tie in at the amp.
