Fat Sac and Pump deal at Red Tag Sports $199 pump plus 2 x 800lb bags.
http://www.redtagsports.com/?avad=2872_b1fb0dd3
http://images.the-house.com/ebay-lp-...0-pkg-rtag.jpg
Wakeboard Wakesurf Fat Sac Ballast 1,600lbs Combo + Pump
Weight you boat out with 2 800lbs bags. This combo gets you to 1,600lbs on the cheap and quickly. This combo includes two 800lbs bags and a sumo pump. NOTE: Make sure to check the weight limit for your boat as going in excess could sink it. Pump The most powerful ballast pump on the market! Key Features of The Straight Line Sumo Pump:
Fills 100 Pounds in 55 Seconds
9 Foot, PVC Armor Hose will Not Kink or Crush
12 Foot, Fused 12V Power Cord for Easy Access Anywhere
Bag 1Launch Pad 800 Lb Ballast Bag Single If you're looking for a ballast bag that you can trust that not only looks great but does its job well, look no further than the Launch Pad 800 Lb. Ballast Bag Single. This ballast bag is designed to provide the user will all of the weight that they need in order to perform at their best. So if you're looking for a great ballast bag that won't let you down when you need support the most, the Launch Pad 800 Lb. Ballast Bag Single may just be what you're looking for. Key Features of the Launch Pad 800 lb Ballast Bag Single:
Where To Use: The Single XL is the largest bag in the Launch Pad line, making it perfect for rear lockers, or anywhere else 800lbs. of weight is needed.
Link System: A leak free connector with a spring-loaded flap that is air and water tight means no gushing water when removing the pump.
Rugged Construction: Designed for years of use, Launch Pad ballast products feature a tough protective outer layer for leak free durability.
Molded TPL Handles: Now you can easily move your bags around where you need them with these molded in handles.
Square Design: A square outline maximizes ballast capacity and space utilization, while minimizing any rolling that may occur.
Dimensions: 24" x 24" x 50"
