Wakemakers has a good how too video in you tube on how to remove the glued in fittings
Thanks for the tip!
The Mojo will hold ALOT of weight. I run 4K plus in ballast and I have have 20 plus people in the boat. Not advising that but the boat handled fine and no problem getting on plane.https://uploads.tapatalk-cdn.com/201...4557a3e3c4.jpg
No problem getting on plane with 4k and a boat full of people? What prop and motor do you have? I'm running an oj 15"×13" on my craz and run 4k ballast. Mine struggles with that weight and a tiny crew. I'm not at a high elevation either.
so you would fill your 4k ballast and still have all those people? Wouldn't the passengers do the same job as the bags?
Hey, new Mojo owner here as well (picked up a 16' model in off season. Haven't been able to get it out other than test drive. The dealer claims its been set up for surfing (1100 bags, timers fixed, etc.) but I just am a little curious. I pulled my bags for winter....does anyone have dimensions on the stock 650's vs. dimensions of 1100 bags so I can compare?
