Is 8’ long enough? Have a 2017 mojo with heater hoses
To much and it doesn't all fit inside the tube, you probably need 4 or 5 feet per hose.
thanks guys, this is great stuff.
now i won't stress about the kids using the heater tubes.
amazing how quickly the oem stuff wears out
Mine were replaced last fall under warranty. The replacement tubes seems to be made with a higher quality material. Time will tell but they are much better than the OEM ones.
Springman: the length is critical. Mine barely fit back under the seat. We have found with the OEM tubes, that if you wait a bit for the tubes to cool down they are easier to get back into the holes. I guess that the expansion when they’re warm makes them just a bit too big to pack into the receptacle/hole.
Tommy2slow or anyone else do you know if the new 2021 have changed vs the 2020 or older ones? Glad they warrantied the hoses I would hope that they just had a bad run of hoses and the one they replaced yours with under warranty is more indicative of the new OEM hoses?
Hi Chuds. I have not seen what Moomba is using for hot tubes on the 2021’s. Perhaps one of the members who has taken delivery of their boat could chime in on what they think of the tubes installed this year.
No worries, I mean worse case I swap them out after they get thrashed and it is good to know you can get replacements and have a few options. Come on open water!
