2 Attachment(s)
2008 Outback V Drivers Seat is Loose, how to tighten? (yep, sounds stupid but ... )
So, I have a 2008 Outback V and the left rail of the drivers seat is loose and the seat rocks a little when moving around. I figured I'd tighten it. Looking a bit closer it seems that the anchors have round tops, go through from the top and must have nuts on the bottom side (under the pedestal cover). I don't see how to get to them. The seat pedestal cover is square, 4 - 5 inches tall and does not seem to have any screws to free it. The only thing I can guess is it has a horizontal flange around the bottom and it's screwed around the edges to the hull (out of sight) and under the sub-floor/carpet. Pics attached. I hope not because what a hassle to pull that up. Or is it?
So yes, kind of a weak question but before I start pulling up the floor wanted to see if anyone on here has experience with this and if I am missing the "simple way" to do it. Wouldn't you think tightening your seat rails to your seat pedestal should be relatively easy??
