Yeah, they look like 3M Command hooks. I hung a 2x4 in my storage unit and ran a row of screw-in bike hooks so I'm not hanging wet jackets in the boat at the end of the day.
The hooks are command strip hooks. I did not want anything to permanently damage the gel coat. They stick on very well but the actual plastic hook pops up and off easily and will sometimes fall into the abyss that is the rear locker of the Max. Not really a big problem but a bit of a pain.
How is the clarity of the water where you boat? These seem like a reasonably priced option over going with the standard rgb sea blaze lights, just wondering if they put out enough light to be seen in our water in south east TX.
I removed the surf tabs and worked on the center plate with it still attached to the hinge. The plates looked pretty bad after a year. I should have taken a before pic.
I don’t believe there will be any performance changes. The water is still being forced down when the tab is down. I believe the Supra plates have a more polished surface.
I sanded the plates using wet/dry sand paper and WD40 as a lubricant, then polished.
Still blows me away how much storage you have in that monster! Also surprised to see the transom tie downs attach to the platform bracket - that seems lit a lot of added stress vs straight up to the hull?
Lights look great though. Hope to see them in person this year.
