Where can I buy one of those swim deck brackets that are mounted to the bottom of the swim deck and pin to the boat? My whole is ripping through from wear and need to replace one of them.
Sent from my Pixel XL using Tapatalk
If you take the bracket to a local welding shop they can weld the hole close and you can re-drill . I just did it to my friends and it came out great.
https://uploads.tapatalk-cdn.com/201...62946585ac.jpg
Tig welded mine then drilled platform brackets and boat brackets to 1/4" so all aligned and I could use a larger pin.
Yeah take it to a welder, will cost you $15-$20. I've had to do it twice.
