Hi, trying to take the floor panels out and can't find the fastener head or type? Any info appreciated.
not sure if the 06 is like the 07 but i would think it is. In my 07 LSV there are two metal panels that sit on top of the gas tank and each panel has 4 screws. They can be hard to find because the carpet gets matted down over the screw heads and it doesn't even look like they are there. The first time i took my panels off it took a while to find one or two of them. It just took some time and patience. Try using a magnet if you need. On the rear panel mine are in corners more or less. Same for the front panel but one of them ( the one closest to the drivers seat) is probably 6 inches or so down from the corner. If you can't find them i can take a picture for you.
yea, no fasteners. I actually have left the screws out because they fit so snug and i have had to pull them up from time to time. Makes it a lot easier without dealing with the screws.
Proper Raised Access Floor Panel Removal and Reinstallation of Raised Computer Floor Panels includes the use of suction cup lifters.
