Will do, thank you!!!
Where would you even add permanent cup holders to a Max in the bow if using the cushion? The entire bow is upholstered with no flat fiberglass surfaces other than the gunnels. I kind of wished they added them to the front of the filler cushion basically in the same place as the cup holders they cover up.
Get 4 cup holders from Trayson & mount them here....[emoji1689]https://uploads.tapatalk-cdn.com/201...b2e9a1bfda.jpg
The blue arrows is where I was thinking. Don't know if there's space at the red arrows but definitely worth considering too
These are the type of hinge:Quote:
Sea-Doo New OEM Sport Boat Seat Hinge Bracket Set 230 Challenger, SP, Wake https://www.amazon.com/dp/B01GVT3K4G..._SanqDb7AB02P4
But there is one major problem.... there is no cross support to mount the rearward hinge to on the max. Only solution would be to build one from hdpe.
Thinking about adding RGB lighting to my Max in the off season. What controller do you guys recommend or should I just buy a roll of RGB LEDs from Amazon that come with their own controller?
I used the wetsounds music controller, but I’m sure the others will work fine too.
I took a queue from you and lithttps://uploads.tapatalk-cdn.com/201...594463f8af.jpg up my speakers. Good tip on the led lights. The best part is the boat was pre-wired for them, so the install was super easy.
https://uploads.tapatalk-cdn.com/201...78fad2db4d.jpg
https://uploads.tapatalk-cdn.com/201...751a28b487.jpg
Awesome inspiring mods to those interiors of those boats. I will probably use them myself!
